Two Oil Plugs?
g520
The oil plug is out. After trying two different Vise-Grips, several Pliers, chisel/hammer and several more things I welded a nut to the oil plug. Pretty brutal approach. The trick to avoid heating the aluminum cases was to weld for only a second at a time and cool in between with water. There was almost no heat transfer to the cases so I don
