pabowers Posted February 19, 2009 Report Share Posted February 19, 2009 HI, all Was wandering how to tell when the chain on my 05 280 pro is tighten corectly? Thanks Patrick Quote Link to comment Share on other sites More sharing options...
jse Posted February 19, 2009 Report Share Posted February 19, 2009 HI, allWas wandering how to tell when the chain on my 05 280 pro is tighten corectly? Thanks Patrick Hi Patrick, Adjust your chain so that you can fit a finger tip in between the top of the tensioner and the underside of the swingarm. You should have enough slack to be able to move the chain up and down a little over 3/4", or 2cm, with the tensioner pulled down Jon Quote Link to comment Share on other sites More sharing options...
