damorev3 Posted February 21, 2009 Report Share Posted February 21, 2009 what exhaust do i get for my ty175 i have seen a few but was thinking of a sammy miller front pipe and the mid box that requires no extra silencer. Quote Link to comment Share on other sites More sharing options...
andy.t Posted February 22, 2009 Report Share Posted February 22, 2009 The one with the tail section is supposed to give more power,if you get the one which has the mid section only I think you will find it has the packing in this section so when its due for changing its going to be a problem. If you get the other one at least you can repack the tail section easily. Quote Link to comment Share on other sites More sharing options...
damorev3 Posted February 22, 2009 Author Report Share Posted February 22, 2009 good point on repacking ,thanks m8 Quote Link to comment Share on other sites More sharing options...
nelly1 Posted November 6, 2013 Report Share Posted November 6, 2013 that said the short one looks great Quote Link to comment Share on other sites More sharing options...
bestrcpilot Posted November 6, 2013 Report Share Posted November 6, 2013 Having run all 3 of the Exhaust pipes on my Ty175. The stock setup was the Quietest one and also the Heaviest. The two piece setup with mid box with rear Silencer a little louder and lighter then stock, did not find any Performance changing the motor. The SM one piece with out rear silencer is the lightest and I did find that the motor did run better and revs better. It is also the loudest. And running the short front pipe also help the motor run better. Quote Link to comment Share on other sites More sharing options...
nelly1 Posted November 12, 2013 Report Share Posted November 12, 2013 how do you fit the one piece do you need a silicon sleve if so what size in mm is it thanks Quote Link to comment Share on other sites More sharing options...
bestrcpilot Posted November 13, 2013 Report Share Posted November 13, 2013 I used a piece of radiator hose on the outside of the pipes. Like on a Bultaco. Quote Link to comment Share on other sites More sharing options...
nelly1 Posted November 13, 2013 Report Share Posted November 13, 2013 ive got one waiting to be fitted along with points condensor plug alter the air box change rear shocks fork oil change probably loads more too thanks for the info Quote Link to comment Share on other sites More sharing options...
earthmover Posted November 15, 2013 Report Share Posted November 15, 2013 Nelly, Demon Tweeks sell Samco heat resistant hoses, in a few different colours. Mark Quote Link to comment Share on other sites More sharing options...
nelly1 Posted November 18, 2013 Report Share Posted November 18, 2013 cheers earthmover fitted the pipe it is loud but what a difference to the way it revs very responsive can anyone tell me what the points gap is supposed to be set it by eye for now Quote Link to comment Share on other sites More sharing options...
