Disappering Front Brake!
betarick
Hi all! i seem to have a problem with my front brake on my 06 rev3 one minute have a good solid front brake the next minute it just seems to go! and when holding front brake on down hill it just goes! if you pump it, it comes back and is solid again! i have changed caliper pistons and seals also fit new pads and bled system out! this seemed to fix it for a while until today when problem returned, should i change master cyl piston and seals? i took cly apart and could see no damage to seals or piston! anyone else had this problem?
Just checked my front disc and it runs true removed pads cleaned pad pin and greased! had another go at bleeding brake using a syringe and back bled from caliper no air? and brake lever feels good til i ride down hill braking and it just goes again! if i release lever it comes back again until i brake again?
I had the exact same problem with my 08 beta when I first go it. the brake disappears here and there... almost killed me downhill one time. Anyways, I actually didn't have to change anything to fix it. I just made sure everything in the system's tight, forward bled the brake, tap the brake line with a wrench while operating the lever to make sure all the air bubbles are out and FILL the brake fluid TOTALLY FULL. I put more than I need in to the reservoir and capped it. Pushed some fluids out while I did this which means almost no air in the reservoir. For some reason, its magically fixed and I haven't had a problem for the past 4 months. Nothing else I tried before worked. My beta dealer tried to fix it too and it still did it after I picked up the bike. So bleed it and make sure reservoir is 100% full. NO AIR ALLOWED hehe.
Edited by AirFruit
Hi all again! fit new cyl seals tonight & bled system again and i have a front brake again! its that good i got finger ache and had to back lever off! cheers AIRFRUIT for the idea of tapping brake line while bleeding it as you say it gets rid of all the air left in system!
