blockbob Posted February 22, 2009 Report Share Posted February 22, 2009 The front brake of my 250sy is binding, have altered it to the limit at the lever end in fact if i remove the lever altogether it still binds! Quote Link to comment Share on other sites More sharing options...
godzilla Posted February 22, 2009 Report Share Posted February 22, 2009 Sounds like the pistons in the caliped are sticking, not too hard to fix. its worth fixing as you disc will wear too! Quote Link to comment Share on other sites More sharing options...
blockbob Posted February 22, 2009 Author Report Share Posted February 22, 2009 Thanks for that ill give em a go, at least their not as hard to get at the carb; iv got that to do as well god help me! Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted February 24, 2009 Report Share Posted February 24, 2009 Yep probably the caliper pistons sticking, however it is always worth checking that the master cylinder piston is moving freely before you start on the calipers. Quote Link to comment Share on other sites More sharing options...
