duckwizard Posted October 21, 2004 Report Share Posted October 21, 2004 Help . Does anyone know of a company that sells aftermarket piston kits. Bought a Cagiva DG350 needs a piston and rings. Maybe some of you lot have one lying around. Quote Link to comment Share on other sites More sharing options...
martinm Posted October 22, 2004 Report Share Posted October 22, 2004 Was this the bike advertised a while back on ebay?? I spoke to some contacts over in Italy and they said that there was nothing new or pattern availble for the DG350. However, measure up your existing piston and ring Steve Reilly at PB engineering in Bristol on 01179 412300 he may be able to help. Steve has about 2500 pistons cross referenced on his computer and its possible that a kit from something else might fit. You will need to measure the outside diameter, pin diameter and gap between pin and top of piston. Good luck Martin Quote Link to comment Share on other sites More sharing options...
toofasttim Posted October 22, 2004 Report Share Posted October 22, 2004 Duckwizard, how's the restoration going? Did you find any other references? Post pics soonest. Quote Link to comment Share on other sites More sharing options...
