Burman 4speed For Ajs/matchless
pat
Hi all,
Im searching for a cover gasket for this Burman cover, http://i633.photobucket.com/albums/uu54/pa...SA071024003.jpg
Have tried the easy paths but no luck..well loctite working allright for now but..., did found the centre gasket though (NOS..crispy..)
Its allways possible to make a special order or mould/cut manually, but will ask if any of you could guide me to a supplier. :rolleyes:
Im also searching for a two seals for this cover, kick start- and gear lever.
* OD 22mm, ID 20.6mm x ~5-10mm
* OD 21.7mm, ID 18.6mm x ~5-10mm
BR, Pat
Edited by Pat
Hi Guy's,
Hi Pat.
Try Simply Bearings for the oil seals, thats were got mine from. You could soak your paper gaskets in water for a while if they are dried up, or make your own. One place I have not tried for gaskets of the top of my head is Draganfly motorcycles in Bungay. You could try them, as they keep some Burman parts. Hope this helps.
Regard's Charlie.
  • 4 weeks later...
