Norton Fork Legs/brake Plate.
trialsrfun
When using the Norton Roadholder lower fork legs how are you anchoring the brake plate. Are you using a brake plate with a lug that engages in the slot between the raised alloy bars on the fork leg or a bolted on metal strip, presumably to the two bolts that secure the mudguard stay.
If using a brake plate with a raised lug to engage in the fork leg, which hub/brake plate is most suitable.
Edited by TrialsRfun
Hi Guy's
Hi TRF.
I think Subira, is right use the mudguard bolt holes, because I have a leg with the slot,and the presure of braking has cracked the leg,from between the slot to the seal holder boss. this was probably done with a large road brake in the fork, but they do seem suspect. So pulling from the two holes from the mudguard bolts seems the best idea.
Regard,s Charlie.
  • 2 years later...
