ginger_ninja54 Posted October 23, 2004 Report Share Posted October 23, 2004 Can anyone tell mewhat is the correct mixture i should be using when mixing my petrol.....? Currentlymixing at 50:1...... Using Silkolene comp2 pre-mix oil I have (what has now been identified as) a '92 BETA SuperTrial(aircooled) Anyone recommend any better oil? What do you all use? Quote Link to comment Share on other sites More sharing options...
neonsurge Posted October 23, 2004 Report Share Posted October 23, 2004 (edited) I run at 80:1 and have heard of people who run at 100:1 According to John Stoodley over at GasGas USA, modern watercooled engines should be fine at 100:1 but I think I'd be constantly listening to the engine for peculiar noises if I ran my mixture that lean! Most people I know run 75-80 although 50 shouldn't do it any harm except maybe a bit smoky and higher risk of oiled plugs. Silkolene Comp-2's fine. I also recommend Ipone semi which has a lovely strawberry smell (yes, really!) Edited October 23, 2004 by neonsurge Quote Link to comment Share on other sites More sharing options...
colly Posted October 28, 2004 Report Share Posted October 28, 2004 motul 600 is the best, i got reccomended of al the spanner gas gas team mechanic, i run mine, @ 70:1 Quote Link to comment Share on other sites More sharing options...
ginger_ninja54 Posted November 4, 2004 Author Report Share Posted November 4, 2004 Any Aircooled riders.... what do you run your mixture at? At 50;1 it seeems a tad smoky. hope its mixture an not a ring gone....... Quote Link to comment Share on other sites More sharing options...
beta boy Posted November 5, 2004 Report Share Posted November 5, 2004 well all a buggered ring will do is lose you power your engine is 2 stroke and that is why you use premic cause it lubes the bearings and ring unlike a 4 stroke where you have oil seperate in the engine Quote Link to comment Share on other sites More sharing options...
