shercoman2k8 Posted February 27, 2009 Report Share Posted February 27, 2009 Finishing off a resto project... 2006 125, what oils need changed.. Engine? Gearbox? Clutch? Found out it still has the oil from its first service after run in... Where do I drain the different oils from? Which oils need done? What oils do I replace them with? Cheers, Jamie Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted February 27, 2009 Report Share Posted February 27, 2009 Well you have to pre mix your oil with your petrol to lubricate the engine, I'm guessing/hoping you already know this. There is no separate engine oil supply. I use recommend Ipone strawberry two stroke oil. Gearbox oil, you need to remove the bottom engine screw next to the sump plate near the gear lever there should be a sticker saying oil or something next to it. Refill from the other side of the bike through the larger aluminium screw after you've put the drain screw back in of coarse, fill with 450cc of gearbox oil, I use recommend Ipone Box 2. The Clutch is lubricated by the gearbox oil, it is a hydraulic clutch though so you can change the hydraulic oil I use recommend Ipone dot 4 brake oil. Check out these Sherco Manuals they explain thing with pictures making it much easier to understand, have a look at "Sherco Setup and Lubrication Guide" for changing the gearbox oil and "Brake & clutch system bleeding manual" for changing the hydraulic oils. Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted February 27, 2009 Author Report Share Posted February 27, 2009 Yeah, I knew about the engine Didnt think though, just shoved it up... I use the strawberry stuff already! Thanks for that... all pretty obvious now, same as every other sherco model... Would atf work? if so what weight and all that? Thanks again! Jamie Quote Link to comment Share on other sites More sharing options...
copemech Posted February 28, 2009 Report Share Posted February 28, 2009 (edited) Yeah, I knew about the engine Didnt think though, just shoved it up... I use the strawberry stuff already!Thanks for that... all pretty obvious now, same as every other sherco model... Would atf work? if so what weight and all that? Thanks again! Jamie You really are,,,,,, Scottish? Everyone knows the 50wt ATF works the best! Edited February 28, 2009 by copemech Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 28, 2009 Report Share Posted February 28, 2009 You really are,,,,,, Scottish? Everyone knows the 50wt ATF works the best! My whole selection of oils are ATF ! Quote Link to comment Share on other sites More sharing options...
copemech Posted March 1, 2009 Report Share Posted March 1, 2009 (edited) My whole selection of oils are ATF ! Aye, you see! A right tite sscootsman can run that crap as premix as well! Actually, the uused stuff from the local garage works better for the premix, as t'is, it always partially burnt already, all you have to do is finish it off! Does samoke a bit, but not a problem less you are the one behind in the que! Ye can puut the crapin ye furks tou! They dun't care!, Oil ye'r friggin chain with the remains, so ye'r recyclin crap! Yeu caneven yews it to spank the monkey if you like, has better lluubricating properties! Edited March 1, 2009 by copemech Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 6, 2009 Report Share Posted March 6, 2009 Aye, you see! A right tite sscootsman can run that crap as premix as well! Actually, the uused stuff from the local garage works better for the premix, as t'is, it always partially burnt already, all you have to do is finish it off! Does samoke a bit, but not a problem less you are the one behind in the que! Ye can puut the crapin ye furks tou! They dun't care!, Oil ye'r friggin chain with the remains, so ye'r recyclin crap! Yeu caneven yews it to spank the monkey if you like, has better lluubricating properties! ATF also stands for Away Tae Ferk. Quote Link to comment Share on other sites More sharing options...
