gser Posted March 3, 2009 Report Share Posted March 3, 2009 OK I have seen where to buy section markers but where can I get hold of the wire section marker holders that are used to define the route of a section? You know the ones, about a foot or so long with a loop at the top that the marker slides into. Quote Link to comment Share on other sites More sharing options...
graeme17 Posted March 3, 2009 Report Share Posted March 3, 2009 We make our own using "plain" rather than high tensile fencing wire. A jig is made by welding a section of scaffolding tube about 6 inches long onto a piece of angle iron. The angle iron can then be clamped into a vice to hold the jig firm. A slot should then be cut into the top of the tube to slide the wire through to hold it while it is formed around the tube (2 or 3 turns works well). The wires can be made any length for different ground types! Quote Link to comment Share on other sites More sharing options...
