milfy Posted March 6, 2009 Report Share Posted March 6, 2009 im looking to change my rear exhaust silencer as its damaged and worn thourgh on the side so anyone recommend a aftermarket one or should i stay with the original silencer Quote Link to comment Share on other sites More sharing options...
twinkletoes Posted March 6, 2009 Report Share Posted March 6, 2009 don tknow what aftermarket ones are available but i d fit an original and fit the straight through internal pipe. sandifords sell them, i think it is a from a crf450 and you cut it to length. made a noticeable power difference i thought, especially if you de coke the rest of the system. check the bush set up where it is attached and renew with the correct washers - there will be play but enough so that when the tyre touches it moves and shouldnt wear through over time Quote Link to comment Share on other sites More sharing options...
tt5th Posted March 6, 2009 Report Share Posted March 6, 2009 I'd stick with the original one, I have the WES one on mine and just think its a bit too crackly for my taste. Quote Link to comment Share on other sites More sharing options...
