beamish owners club Posted March 8, 2009 Report Share Posted March 8, 2009 I have a 1962 C15 that I am converting to trials, I have junked the worn concentric carb and have bought an Amal 622 and a 1.5" long inlet manifold extension, it will be running PVL. Is anyone else running a 622 on a C15 and can they tell me what jetting they use and what needle position they find best? Quote Link to comment Share on other sites More sharing options...
bsaweezer Posted March 11, 2009 Report Share Posted March 11, 2009 Hello, regards jetting etc, i have just spent the past two weeks doing the same, I have a bsa C15 trials fitted with a new 622 and PVL, after some nights of buggering about i have found it runs best on the following 106 needle jet, middle slot on needle, main jet on 140 and no3 slide. i am running a cone type air filter. Hope this helps regards Bsaweezer. Quote Link to comment Share on other sites More sharing options...
trialsoldtimer Posted March 20, 2009 Report Share Posted March 20, 2009 I have a 622 which I have used on a 250 cub and currently on a 410 ajs. It has 2 stroke jetting and needle and runs perfectly on either bike. On the cub I use a 110 main jet and a 140 on the ajs. I also ran a 140 on my 500 ariel so I would suggest you run smaller than this on a 250 (try a 120). Other settings are 106 needle jet, no 3 slide, needle in middle. Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted March 30, 2009 Author Report Share Posted March 30, 2009 Thank you both for your advice, I have a better ideao fo what I need now. Cheers, Jim Quote Link to comment Share on other sites More sharing options...
