honda_trials Posted March 8, 2009 Report Share Posted March 8, 2009 Wally has written to me with the following gearbox problem - any dieas? "I have a 1986 TLR200 with shifting problems. When you tap the shifter into first gear the shift arm will drop 90 degrees down from its neutral position. Think of the shift lever pointing at the ground. You then have to manually return the shift lever to the horizontal position. It shifts fine from neutral to 2nd, 3rd, 4th and so on. It also shifts fine going down through the gears until you try going from 2nd gear to first, at this point the shifter fill end up pointing vertically at the ground. Any thoughts on the problem?" Cheers. Quote Link to comment Share on other sites More sharing options...
wayne_weedon Posted March 12, 2009 Report Share Posted March 12, 2009 No TLR expert but most selectors work in similar ways. Pin on the selector drum broken or dropped out? He needs to take the primary cover off and investigate anyway, nearly always a clutch off job too. Wayne.... Quote Link to comment Share on other sites More sharing options...
NewTLR87 Posted May 9, 2021 Report Share Posted May 9, 2021 I just currently recently bought a TLR. Test drove it and was fine. Then get it home and it has the exact same issue as the one you described. Did you ever find the reason/solution? Quote Link to comment Share on other sites More sharing options...
