Carbon Build Up In Manifold
chubs
hi can anyone reccomend a good way to remove the carbon build up in a manifold,mine seems like its welded on.
You can take the pipe off and spray the inside with oven cleaner and let it sit overnight. That will loosen the carbon and make it easier to scrape off. Careful though, it's nasty stuff and you'll want to carefully rinse the pipe before scraping and don't get any in your eyes.
Jon
thanks both i will try the oven cleaner method as the bikes top end is apart at the minute which rules out the rev method,never thought aabout the oven cleaner i used to use it to strip the anodized finish off gsxr frames when building streetfighters,so i know its pretty potent stuff.thanks again
