315 Front Sprocket Set Up
cypher
315 transmission
can anyone with a 315 have a look at theirs and tell me if the sprocket set-up matches that on the link above. ie circlip, splined washer, sprocket, splined washer, circlip, thrust washer
mine only has the two circlips, one splined washer and the sprocket. yet everything is secure and there doesnt seem to be room for the rest.
so is the diagram wrong or has a previous owner done something to mine.
if yours is the same as mine should the single splined washer be inboard or out of the sprocket.
i ran it outside at the last trial and the sprocket has worn on the inside so i'll try it one the inside on the next ride to see if this lines things up better.
