petejohn Posted March 14, 2009 Report Share Posted March 14, 2009 Hi Need to repack the silencer on a 04 gas gas 200. Where is the best place to cut it open. Top straight across top on the grove thats pressed into the silencer bottom or length ways. Need to know before i attack it with hacksaw angle grinder and tin opener. Feet up Pete Quote Link to comment Share on other sites More sharing options...
pumpkin trials Posted March 14, 2009 Report Share Posted March 14, 2009 dont cut the silencer at all just drill out the 4 pop rivets and remove the end take out the baffle and remember which way it came out get a bag of silentsport or similar from gas gas uk or local if you can put the baffle back in the right way and pack the stlentsport around it you should use 2/3 of the bag for 1 fill as this geives the correct fill then put some in the end piece and put back on with pop rivets Quote Link to comment Share on other sites More sharing options...
mont Posted March 15, 2009 Report Share Posted March 15, 2009 Dooh no rivets in an o4 silencer, so just cut the end where the rivets would normaly be. Then follow previous instructions and reweld. Quote Link to comment Share on other sites More sharing options...
