endurojunkie Posted March 15, 2009 Report Share Posted March 15, 2009 Can someone tell me if there is a drain plug for the transmission oil on my TY350? All I see is one screw/bolt on the bottom? Hints? Quote Link to comment Share on other sites More sharing options...
tt5th Posted March 15, 2009 Report Share Posted March 15, 2009 Its at the back of the engine towards the bottom. Its screwed in horizontally rather than vertically. Fairly big bolt, M12 or M14 I would guess. Quote Link to comment Share on other sites More sharing options...
endurojunkie Posted March 15, 2009 Author Report Share Posted March 15, 2009 Thank you. Not sure what was in there or how long it had been in there....nasty looking stuff!! Quote Link to comment Share on other sites More sharing options...
kevin j Posted March 17, 2009 Report Share Posted March 17, 2009 pai to access. I had to remove the skid pan each time. Rear mounts on the frame are prone to stripping out the threads, and no room for a nut, so I did not want to remove those bolts any more than necessary. I slotted the skid plate enough to get a ratcheting gear wrench up from below. much easier now. kcj Quote Link to comment Share on other sites More sharing options...
