colly Posted October 28, 2004 Report Share Posted October 28, 2004 i have a 1998 techno 200, when the bike is lent on an angle the petrol drips out of a pipe, at the bottom, i read somewhere this pipe was to give it pressure but not sure. i have had the float out made sure it is not bent, it still leaking is there a cure for this? thanks Quote Link to comment Share on other sites More sharing options...
neonsurge Posted October 28, 2004 Report Share Posted October 28, 2004 Don't know if the Techno uses the same Mikuni carb as the Rev-3, but on later bikes the fix is to simply connect the two overflow outlets together with a single piece of tube. Quote Link to comment Share on other sites More sharing options...
beta boy Posted October 28, 2004 Report Share Posted October 28, 2004 the techno and the rev3 have the same carb. neonsurge do you know which two it is, is it the one near the choke and the one on the float bowl. is it it another combination Quote Link to comment Share on other sites More sharing options...
sirdabsalot Posted October 28, 2004 Report Share Posted October 28, 2004 Beta Boy--Yes, the one near the choke (which is a vent) and the one near the float bowl (overflow). Cheers, Richard Quote Link to comment Share on other sites More sharing options...
beta boy Posted October 28, 2004 Report Share Posted October 28, 2004 thanks sirdabsalot. know i wont get any more petrol patches onmy drive from when it is on the stand Quote Link to comment Share on other sites More sharing options...
colly Posted October 29, 2004 Author Report Share Posted October 29, 2004 does yours leak aswell beta boy? and why are they leaking do they do this when they are new bikes out of the factory or is it an age thing? Quote Link to comment Share on other sites More sharing options...
sirdabsalot Posted October 29, 2004 Report Share Posted October 29, 2004 They leak when the float is out of adjustment or when there is dirt keeping the float needle from closing. When the floats are properly adjusted you should not have any leakage, and you should never have fuel come out the vents. Keep in mind, I'm referring to normal upright (at least somewhat upright) conditions. Cheers, Richard Quote Link to comment Share on other sites More sharing options...
rev3guy Posted October 29, 2004 Report Share Posted October 29, 2004 I have copied the post in the Mechanics Section from Billy T on how to adjust your Mukuni on the Beta: Re-posted for future use; thank you Billy and RonM! Mikuni Carb Setup By Billy T After receiving my 02 Beta Rev 3 I am very pleased with the bike. I am getting quite a few recommendations on how to set the bike up and what areas to change or set. One particular area is the carb. I have heard many statements regarding the float level and how to set it up. This setting of the Quote Link to comment Share on other sites More sharing options...
