penno350 Posted March 17, 2009 Report Share Posted March 17, 2009 Whats the technique for removing the roller bearings in the swinging arm and rear suspension? Is heat recommended or do they just drift out? Quote Link to comment Share on other sites More sharing options...
shnaft Posted March 17, 2009 Report Share Posted March 17, 2009 Hi,i use a smaller size socket and press them out on a vice. Quote Link to comment Share on other sites More sharing options...
lee harris Posted March 17, 2009 Report Share Posted March 17, 2009 you need a big socket behind it in the vice to push the bearing into, otherwise you will be pushing into the vice jaws. A hot air gun helps as alu expands more than a steel bearing HTH Lee Quote Link to comment Share on other sites More sharing options...
