silverfox Posted March 17, 2009 Report Share Posted March 17, 2009 Hi: newby to forum here I am restoring a '68 Greeves Ranger which is a long distance trials unit that was, I believe, only sold in the States. Currently I am attempting to install a solid state ignition system that I bought from Electrex World. It is their kit no. STK-970 which is supposed to fit any of the 9E/32A/34A engines. The problem I am having is that when the stator plate is installed, it cannot be rotated far enough to bring the timing marks into alignment. Does anyone here have any experience with this kit? Thanks Mike Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted March 18, 2009 Report Share Posted March 18, 2009 Mike, Welcome to TC. It's not normally the done thing to duplicate posts but may I suggest that you ask your question in the pre-65 section below. If you post the heading as "Help needed with Greeves Ranger ignition" then you may attract the attention of someone with the relevant info who doesn't look at the Introduction section. Good luck with the bike. Pete Quote Link to comment Share on other sites More sharing options...
