Ok, It's Time For Crank Seals
spokerider
There are no other seals inside the cases. I would put all back together and if anything leaks oil replace the seals then which is easy enough to do. After replacing the shifter seal, which you already replaced, the only other seal is behind the countershaft sprocket but like I said try it, if it leaks, replace it.
