jokerr Posted March 19, 2009 Report Share Posted March 19, 2009 i beleive there is a removable weight on the flywheel. i gather that when removed, the bike will become more responsive and fruity. whats your thoughts (2004 rev3 250) ta. Quote Link to comment Share on other sites More sharing options...
fivemeister Posted March 19, 2009 Report Share Posted March 19, 2009 whats your thoughts Its been done before mate - lots of times - follow the link below or do a search for dozens of similar threads. http://www.trialscentral.com/forums/index....flywheel+weight Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted March 19, 2009 Report Share Posted March 19, 2009 Hi.There is a flywheel weight you can remove.I have the same bike as you and I haven,t and I won,t remove it.Reason being its plenty enough as it is for me.Particularly when I,m in the process of falling off I generally have this habit of trying to stay on,often by holding on to the handlebars,which ends up with me twisting the throttle and loop the loop one way or the other.If it was any more fruity or aggresive I would be scared.Have you got a fast action throttle?They can make a difference.Also cakky silencers slows up things.Also I remember reading somewhere here that the flywheel weight helped in UK conditions,something to do with traction in the wet.But maybe you are an ace rider and need as much grunt as possible.I,m not and I find it plenty as it is.Thats my opinion and I haven,t tried it without.People do say it makes em frisky.Try it.You can always put it back again.All the best Quote Link to comment Share on other sites More sharing options...
jokerr Posted March 19, 2009 Author Report Share Posted March 19, 2009 thanks guys. checked out previous threads and if more than 50% leave it on then thats good enough for me. looks like it's a suck it and see option. but defo not an ace rider at this time so will focus on not falling off and look at it at a later date. ta. Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted June 17, 2009 Report Share Posted June 17, 2009 Hello again-just realised after 8 months that I don,t have a weight on the flywheel .Just tried it with one on and not quite sure if I like it.Smooth it is,possibly spongey,maybe even dull. I can see it coming off fairly soon.tis lovely smooth though.I will see how it goes.Shows how much I know ........ Quote Link to comment Share on other sites More sharing options...
braddon Posted June 17, 2009 Report Share Posted June 17, 2009 I am thinking of doing this. Is it as simple as removing the cover and unbolting the weight from the flywheel or is there more to it? Thanks Quote Link to comment Share on other sites More sharing options...
gaz Posted June 17, 2009 Report Share Posted June 17, 2009 I am thinking of doing this. Is it as simple as removing the cover and unbolting the weight from the flywheel or is there more to it? Thanks if you can take the flywheel off or have an impact gun then its dead easy to counter sunk screws, remove the spacer when you put the cover back on.......... thats it!!!! Quote Link to comment Share on other sites More sharing options...
braddon Posted June 17, 2009 Report Share Posted June 17, 2009 thanks will attempt this tomorrow!! Quote Link to comment Share on other sites More sharing options...
samo Posted June 18, 2009 Report Share Posted June 18, 2009 Can somebody attach picture of flywheel? I don't know what it is Quote Link to comment Share on other sites More sharing options...
blackrandomapple Posted June 18, 2009 Report Share Posted June 18, 2009 Can somebody attach picture of flywheel? I don't know what it is Here is the flywheel without the weight, The weight fits on to the flywheel using the two holes u can see in the pic Quote Link to comment Share on other sites More sharing options...
