bhg Posted March 23, 2009 Report Share Posted March 23, 2009 I cant figure out how to remove the fork oil seal retaining circlips on my 1999 TXT 270 I have watched the video for later models that have wire circlips, but mine have flat ones ( like the ones that have a loop on each end, but without the loops ) They need to be closed up to get them out but how !!!!!! Please help Quote Link to comment Share on other sites More sharing options...
jse Posted March 24, 2009 Report Share Posted March 24, 2009 I cant figure out how to remove the fork oil seal retaining circlips on my 1999 TXT 270I have watched the video for later models that have wire circlips, but mine have flat ones ( like the ones that have a loop on each end, but without the loops ) They need to be closed up to get them out but how !!!!!! Please help I use a stout pick to pull one of the ends outward enough to get another pick in between the clip and the collar, they come out easily after that. Be careful to retain control of the clip as they can spring out rather forcefully. Jon Quote Link to comment Share on other sites More sharing options...
bhg Posted March 24, 2009 Author Report Share Posted March 24, 2009 Hi Jon Did exactly what you said and it worked I used a scriber with a slight bend at the end Cheers BHG Quote Link to comment Share on other sites More sharing options...
