shercoben Posted March 24, 2009 Report Share Posted March 24, 2009 Just a Quickee! Whats the difference between a keihin carb and a factory fitted Dellorto carb? I have a 05 sherco 290. if i put the keihin carb in what difference will it make? Thanks, Sherco Ben Quote Link to comment Share on other sites More sharing options...
ham2 Posted March 24, 2009 Report Share Posted March 24, 2009 The Dellorto is a 26mm standard carb for most bikes.... ..To put it bluntly the Keihn is a 28mm? carb for experts....if you fit one the bike will lose some low-rev grunt at the expense of gaining mid/top end punch. I hear you can fine tune the Keihn more than the Dellorto but you are still looking at a lot of power. I've only test ridden a couple of bikes fitted with a Keihn and even though the throttle response was nice and crisp there was just too much wallop for me. Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted March 26, 2009 Report Share Posted March 26, 2009 I wouldn't ride mine without one, they are that good! I don't really agree with the comment that it losses low end grunt, in theory it should but in practise I think it gains low end as well, just because you can get it to run so much cleaner, the D shape slide is claimed to help the throttle response and I agree. As the Keihin runs so clean it feels a lot smoother off the bottom end making it easier to ride if you can handle the power! Quote Link to comment Share on other sites More sharing options...
