marcustyson Posted March 28, 2009 Report Share Posted March 28, 2009 Does anyone know the diameter of the splined starter shaft on a 1995 Beta Techno? Quote Link to comment Share on other sites More sharing options...
stork955 Posted March 28, 2009 Report Share Posted March 28, 2009 Gday, I can measure mine for you if you like. Why do you need this if I might ask? Cheers, Stork Quote Link to comment Share on other sites More sharing options...
marcustyson Posted March 29, 2009 Author Report Share Posted March 29, 2009 I need a replacement kickstart - or at least the part the connects to the splined shaft. And I've been quoted upwards of Quote Link to comment Share on other sites More sharing options...
stork955 Posted March 29, 2009 Report Share Posted March 29, 2009 Shaft measures 14.7 mm. Its a fairly fine spline - keep in mind that its "left-handed" and splines can vary. Good luck. HTH Cheers, Stork Quote Link to comment Share on other sites More sharing options...
marcustyson Posted March 29, 2009 Author Report Share Posted March 29, 2009 Many thanks for that - I was hoping to find a cheaper fix - but I suspect I'll have to go the o.e. route. Cheers all the same. Quote Link to comment Share on other sites More sharing options...
