motojojo Posted March 29, 2009 Report Share Posted March 29, 2009 My bike is almost perfect just needs a little more low end, I'm afraid the added flywheel would slow it down to much. If I had the Ducati program I could tune it down a bit, but I don't. Quote Link to comment Share on other sites More sharing options...
husky Posted March 29, 2009 Report Share Posted March 29, 2009 There are 4 power curves in the ignition on this bike,but you need the software from gas gas to do it.Your importer may be able to help,gas gas uk used to do it.The one i had was programmed so it was softer at the bottom and had a monumental mid and top end.Alternatively theflywheel weight takes the sting out of the bottom with no adverse effects,still comes in plenty hard enough whenyou need it,and makes it harder to stall,good mod in most peoples opinion Quote Link to comment Share on other sites More sharing options...
