ice_marky Posted March 30, 2009 Report Share Posted March 30, 2009 hi can anybody tell me the correct tyre presure, for dry and muddy or is there just 1 presure for all cheers ice Quote Link to comment Share on other sites More sharing options...
tt5th Posted March 31, 2009 Report Share Posted March 31, 2009 As a rule 6psi in the front and 4psi in the rear works well in most conditions. The lower the better on mud but it depends on the tyre and age of it, new tyres and different makes have different stiffness of sidewalls. I was running my IRC rear at 2psi for the last two very muddy trials but as it's broken in I've put it up to 3.5psi as I'm worried that it'll come off the rim. Not had a tyre come off the rim yet so i'm not sure quite how far you can push it. Quote Link to comment Share on other sites More sharing options...
ice_marky Posted March 31, 2009 Author Report Share Posted March 31, 2009 As a rule 6psi in the front and 4psi in the rear works well in most conditions. The lower the better on mud but it depends on the tyre and age of it, new tyres and different makes have different stiffness of sidewalls. I was running my IRC rear at 2psi for the last two very muddy trials but as it's broken in I've put it up to 3.5psi as I'm worried that it'll come off the rim. Not had a tyre come off the rim yet so i'm not sure quite how far you can push it. thanks i will go half way 3.5 rear can not go to wrong cheers ice Quote Link to comment Share on other sites More sharing options...
