Rev3 Swinging Arm Spindle/ Bolt
totalshell
Hi,
Had mine out a while ago, and took my mates out on Saturday, it is just the bolt with a washer and a nut on the end, so it will bash through.
Bear in mind it isn't the toughest material though when you bash it through, and you'll probably find that jiggling with the swinging arm and maybe even loosening off the engine mountings at the back will give it a bit more movement if it is really tough to come out.
Best of Luck,
Bob
wow that thing didnt want to come out.. unlike most bolts /shafts that once they start moving your on your way .. not this mother way no. it wanted to play rough and needed 2lb of persuasion for every hard fought mm
still can only be one winner.. thankfully Garys got another spindle in the post as we speak
