zarkoff Posted April 3, 2009 Report Share Posted April 3, 2009 hi there does anybody know where i could get a decent and accurate tyre pressure gauge suitable for trials ,i mean low pressure i did see one at a trial one day so i know you can get them any help would be appreciated thanks . Quote Link to comment Share on other sites More sharing options...
jse Posted April 3, 2009 Report Share Posted April 3, 2009 hi there does anybody know where i could get a decent and accurate tyre pressure gauge suitable for trials ,i mean low pressure i did see one at a trial one day so i know you can get them any help would be appreciated thanks . Of course your dealer may have one, or you could try a local dealer that caters to the car racing crowd. Make sure it's a short-range gauge, like 1-15 or a max of 1-30 psi type (here in the U.S.) as they are usually calibrated to an accuracy of about 2% (more expensive ones are usually more accurate), so a 1-100 psi gauge could be off 2 psi, which is not good for measuring the pressures we run our tires at. Jon Quote Link to comment Share on other sites More sharing options...
stuartcmorrison Posted April 3, 2009 Report Share Posted April 3, 2009 (edited) i just bought one this week on ebay from motomerlin. Edited April 3, 2009 by stuartcmorrison Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 3, 2009 Report Share Posted April 3, 2009 hi there does anybody know where i could get a decent and accurate tyre pressure gauge suitable for trials ,i mean low pressure i did see one at a trial one day so i know you can get them any help would be appreciated thanks . look here http://www.trialsbits.co.uk/product_info.p...products_id=525 Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted April 3, 2009 Report Share Posted April 3, 2009 Best tyre guage I've ever used! Simpl to use and is about the size of a screwdriver, fits in a bumbag nicely, clear display in all lighting conditions. Its accurate to about 1/10 psi. Just press it against the valve, take it off and look at the display, doesn't take ANY time for the pressure to appear on screen. Really cheap too for what it is, works upto around 70 psi so suitable on the the cars too! Quote Link to comment Share on other sites More sharing options...
zarkoff Posted April 4, 2009 Author Report Share Posted April 4, 2009 thanks everybody i will certainly have a look . thanks again . zarkoff. Quote Link to comment Share on other sites More sharing options...
cg125 Posted April 5, 2009 Report Share Posted April 5, 2009 (edited) I've never had much luck with the digital gauges. I tried a couple then gave up and got a proper one from Motomerlin. Edited April 5, 2009 by cg125 Quote Link to comment Share on other sites More sharing options...
