Gearbox Oil Capacity Rev3
ming
Anyone know what the capacity is for the gearbox oil on a 2000 model Rev3 250?
And what brands/type would you recommend?
I'd really like it if there was a manual in pdf format I could download instead of badgering all of you guys!
Had a look at that site but there was only a manual for 2008 models.
I've dropped the gearbox oil out and refilled it with ATF fluid which seems to be recommended - about 500ml did the job.
Put in new rear brake pads as well, although I had to file down some of the meat as they were a tad too wide for the disc, even with the pistons fully in!
