315 - Softening Power Delivery?
skov
Try changing the throttle from a 'fast action' one to a 'slow action' one. Throttles Link
You could also gear it down a little depending on what setup you have at the moment. Try changing the front sprocket for a 9 tooth one if it's still on the standard 10T one.
Thanks Guys.
I've ordered a slow action throttle, so I'll see if that helps for starters. Hopefully it'll turn up in time for the weekend!
Does anyone know if it's possible to retard the timing a little?
Cheers,
John
  • 2 weeks later...
  • 1 month later...
Have you got the washer in the front pipe still? if not, put one back in!
Just had the exhaust apart - I couldn't see any washers in there. But I also couldn't see any washers on the parts diagram!?
Alright Dave,
The washer will be a large one that effectively reduces the diameter of the pipe at the point it bolts to the head. Restricted mopeds have similar thing and it's usually a big washer with a big 'ole and fits between head and exhaust.
Dave
