dickiem Posted April 12, 2009 Report Share Posted April 12, 2009 (edited) Hi, just got hold of an '03 Beta 80 for my son, what a cracking bike Just a couple of minor niggles: 1) It appears to seep oil from the seal around the output shaft (the one the gearbox sprocket is fixed to). Any ideas how big a job it is to fix and where to get a replacement seal from? 2) One of the fork seals is leaking slightly, how big a job is that to change? Edited April 12, 2009 by dickiem Quote Link to comment Share on other sites More sharing options...
muppet Posted April 13, 2009 Report Share Posted April 13, 2009 from memory both jobs are relatively easy, especially fork seals. the easiest place to get both seals are from Lampkins as i remember the fork seals are slightly unusual either 10 or 11mm thick although you can get away with a thinner standard seal, but lampkins are reasonably priced anyway Quote Link to comment Share on other sites More sharing options...
dickiem Posted April 13, 2009 Author Report Share Posted April 13, 2009 I'm guessing the output shaft seal is accesible just by removing the gearbox sprocket and prising it out? Quote Link to comment Share on other sites More sharing options...
