sherco25016 Posted April 19, 2009 Report Share Posted April 19, 2009 what gear box oil should i use on my sherco 250 03 thanks josh Quote Link to comment Share on other sites More sharing options...
copemech Posted April 19, 2009 Report Share Posted April 19, 2009 what gear box oil should i use on my sherco 250 03 thanks josh The factory spec is 10-40, although many manufacturers of motorcycle lubes use a different scale, referred as light gear oil. The Maxima is 80wt as example. Some use ATF, tends to make the clutch a bit snappier! Quote Link to comment Share on other sites More sharing options...
tryalsryder Posted April 20, 2009 Report Share Posted April 20, 2009 I use the light weight Maxima 75wt Quote Link to comment Share on other sites More sharing options...
1sherco1 Posted April 20, 2009 Report Share Posted April 20, 2009 i have found pj1 ultra light cluch tuner really good Quote Link to comment Share on other sites More sharing options...
neo Posted April 24, 2009 Report Share Posted April 24, 2009 Castrol Sports Edge 5w 30 Best of balance. Neo Quote Link to comment Share on other sites More sharing options...
