Gear Oil
sherco25016
  sherco25016 said:
what gear box oil should i use on my sherco 250 03
thanks josh
The factory spec is 10-40, although many manufacturers of motorcycle lubes use a different scale, referred as light gear oil. The Maxima is 80wt as example.
Some use ATF, tends to make the clutch a bit snappier!
:thumbup:
