gazzaecowarrior Posted April 21, 2009 Report Share Posted April 21, 2009 Going to dekoke my steel TY175 exhaust. Anybody know the ratio or quantities of caustic soda to water that should be used ? Regards Gareth Quote Link to comment Share on other sites More sharing options...
stormy normy Posted April 22, 2009 Report Share Posted April 22, 2009 I have tried Caustic soda with little or no success. The best way that I have found is White Spirit, allow it to soak for several hours, drain off the excess, stand well back and let it burn, dont worry it will soon burn itself out, then have a good tap and scrape and a lot of the carbon will come out. It worked for me. Quote Link to comment Share on other sites More sharing options...
totalshell Posted April 22, 2009 Report Share Posted April 22, 2009 i've always had most success soaking the thing in diesel or petrol, then setting the thing alight ( stand back and let it burn ) then give it a good old scrap with a bent coat hanger and the stuff will fall out. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted April 22, 2009 Author Report Share Posted April 22, 2009 Thanks for the advice guys. I will give the burning idea a go rather than the caustic soda. Fortunately I'm a nurse so if it all goes wrong and I end up on a burns unit at leat I should get good treatment !!! Gareth Quote Link to comment Share on other sites More sharing options...
wayne_weedon Posted April 22, 2009 Report Share Posted April 22, 2009 If its a steel silencer then a hot air gun works a treat to burn off the oily deposits and make the rest fairly easy to remove. It's smoky and dramatic once the stuff starts to burn off. I wouldn't use any fuel to get it going, the oil alone will do that. Wayne.... Quote Link to comment Share on other sites More sharing options...
totalshell Posted April 22, 2009 Report Share Posted April 22, 2009 when done dont forget to remove the root cause of the carbon in the first place. use a smokeless oil (synthetic) set the carb nice and lean ( not too far) you'll know its right when the plug is nice and dry and clean Quote Link to comment Share on other sites More sharing options...
lee harris Posted April 22, 2009 Report Share Posted April 22, 2009 All fantic exhausts were stuffed with steel wool. If you burn it out as above, the steel wool will burn completely. Then again there is no other way to get it clean. Or you cut it open, burn out as above and repack. Look at the 200 on the exmoor videos. it sounds like a mad bee. We cut and cleaned but did not repack. It needed to go up on the jetting over std though..... lee Quote Link to comment Share on other sites More sharing options...
totalshell Posted April 22, 2009 Report Share Posted April 22, 2009 similar on a beta, the rear silencer can have the stuffing taken out then de carboned but the first 'expansion box' has no way of opening it up so dont light that. the front pipe responds nicely though to a good bar b que Quote Link to comment Share on other sites More sharing options...
stork955 Posted April 22, 2009 Report Share Posted April 22, 2009 Gday, if you have a local engine reconditioning place, get them to put it in their hot tank( parts cleaner) - it'll remove the carbon and paint and leave everything else. My local blokes do this for nothing for me. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
subanator Posted April 24, 2009 Report Share Posted April 24, 2009 (edited) I didnt get a good result with a hot tank parts washer, the Robowash solution removes the oily substance, but leaves the hard carbon deposits. I used a sandblaster to clean that out last time, but very gently and minimally applied, it is very abrasive to the bends. Also I used a length of braising rod twisted into a small spiral in a battery drill, and wicked at the bends to remove the deposits to good effect. Good synthetic doesnt eliminated burnt carbon, it lessens it. So be regular with maintenance and dont let it build up after more than a season or two. Edited April 24, 2009 by subanator Quote Link to comment Share on other sites More sharing options...
stork955 Posted April 24, 2009 Report Share Posted April 24, 2009 Gday, was that a dip type hot tank or one of the dishwasher styled ones? Cheers, Stork Quote Link to comment Share on other sites More sharing options...
spokerider Posted April 26, 2009 Report Share Posted April 26, 2009 Never have done this to a Yamaha, but did use lye / H20 on a Cta 348 exhaust.........worked somewhat.......used a propane torch to burn out the residue........also worked........ended up cutting into the silencer with a cut-off tool, repacking with glass pack and welding it up again. Time and effort wise, the latter method was most efficient / effective. So if you weld........ Quote Link to comment Share on other sites More sharing options...
