bikemad Posted April 26, 2009 Report Share Posted April 26, 2009 My 04 Sherco 250 wont move when in gear with clutch pulled in,is this normal goes in to gear ok when running. Thanks Ian Quote Link to comment Share on other sites More sharing options...
copemech Posted April 26, 2009 Report Share Posted April 26, 2009 My 04 Sherco 250 wont move when in gear with clutch pulled in,is this normal goes in to gear ok when running. Thanks Ian Well, they do seem to drag a bit, specially when the oil is cold. As long as it starts (kicks through) easily enough whild in gear, and does not want to creep a lot(pull you) at idle in gear, it is probably ok. If you are getting too much drag it is time for new plates due to warpage. Quote Link to comment Share on other sites More sharing options...
