bikemad Posted April 28, 2009 Report Share Posted April 28, 2009 I am not happy with a noise at idle on my 04 Sherco 250,is there a bearing behind clutch basket that can make a rattle,it sounds like it is in that area?,anybody else had this. Many thanks Ian Quote Link to comment Share on other sites More sharing options...
copemech Posted April 29, 2009 Report Share Posted April 29, 2009 I am not happy with a noise at idle on my 04 Sherco 250,is there a bearing behind clutch basket that can make a rattle,it sounds like it is in that area?,anybody else had this. Many thanks Ian These things are difficult to quantify long distance, althou there is a "normal" rattle in this area due to primary gears and such. This sound will change when the clutch is pulled in. And it will also be worse using thinner oils like ATF. Still, some is normal! Quote Link to comment Share on other sites More sharing options...
