Sherco 250 04
bikemad
I am not happy with a noise at idle on my 04 Sherco 250,is there a bearing behind clutch basket that can make a rattle,it sounds like it is in that area?,anybody else had this.
Many thanks Ian
These things are difficult to quantify long distance, althou there is a "normal" rattle in this area due to primary gears and such. This sound will change when the clutch is pulled in. And it will also be worse using thinner oils like ATF. Still, some is normal! :blink:
