nzralphy Posted April 29, 2009 Report Share Posted April 29, 2009 Hi all. Beta 08 250 4t. My kick start leaver broke the other week... a new one is here now so am happy. Has anyone else had a kick start break on them? Hummmm......there appears to be a silly stress riser machined into the stub shaft Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted April 29, 2009 Report Share Posted April 29, 2009 The one on my dad's beta 4t has had so much wear & tear it is probably about to fall off, it's only just about hanging on. Quote Link to comment Share on other sites More sharing options...
spike123 Posted April 30, 2009 Report Share Posted April 30, 2009 Had the same problem earlier this year ,it appears to be a bad batch of castings,the replacement kick start was slightly different to the original I guess Beta have had a number of similar problems on the 4t.... Quote Link to comment Share on other sites More sharing options...
jagman Posted April 30, 2009 Report Share Posted April 30, 2009 Yes yes. There is a replacement kit including a new kick start axis. Was quite far away when it broke so luckily the 4 strokes are easy to push start. They also have had problems with the kick start gears (wheel/sprocket); which they also have a replacement kit for. This one is bit trickier to change as you have to remove the clutch basket... Apart from that and a broken gear shaft (also replaced) I have had no major problems with mine! /TJ Quote Link to comment Share on other sites More sharing options...
godzilla Posted May 1, 2009 Report Share Posted May 1, 2009 How much did a new kickstart set you back? Quote Link to comment Share on other sites More sharing options...
