markmaltby Posted May 3, 2009 Report Share Posted May 3, 2009 My friends Txt 280 is making a terrible noise which appears to be coming from the bearing behind the flywheel,is it possible to change the bearing without fully stripping the engine. Any help appreciated Thanks Mark Quote Link to comment Share on other sites More sharing options...
mikee Posted May 4, 2009 Report Share Posted May 4, 2009 Quick anwser is NO... Its not a big, but does take time and a few tools. Quote Link to comment Share on other sites More sharing options...
markmaltby Posted May 4, 2009 Author Report Share Posted May 4, 2009 Thanks Mikee for the reply,not really the response i was hoping for but it really needs sorting so i will have to bite the bullet and sort it for him. Is there any special tools required other than a flywheel puller. Any hints and tips greatly appreciated Thanks Mark Quote Link to comment Share on other sites More sharing options...
jse Posted May 4, 2009 Report Share Posted May 4, 2009 Thanks Mikee for the reply,not really the response i was hoping for but it really needs sorting so i will have to bite the bullet and sort it for him.Is there any special tools required other than a flywheel puller. Any hints and tips greatly appreciated Thanks Mark What year and model is it? The earlier "Edition" models are quite different from the newer "Pro" engines. Jon Quote Link to comment Share on other sites More sharing options...
markmaltby Posted May 6, 2009 Author Report Share Posted May 6, 2009 Hi The bike is a 2000 txt 280 not sure if it is a pro as the stickers are missing. Quote Link to comment Share on other sites More sharing options...
jse Posted May 6, 2009 Report Share Posted May 6, 2009 Hi The bike is a 2000 txt 280 not sure if it is a pro as the stickers are missing. Hi! You have the older type engine, often referred to as the "Edition" model, after the last ones off the assembly line. It's fairly straightforward to work on and and the features are common to most two-strokes, unlike the Pro engine which has features unique to only the Pro design. You'll need a flywheel puller and I'm pretty sure the 2000 has the Kokusan Analog System. The flywheel hub threads will look exactly like the normal Japanese pullers will work, but you will need a special puller with right-hand threads ("regular" Japanese pullers are left-hand threads). Possibly a crank puller will be needed, but otherwise, normal shop tools will be all you need. Jon Quote Link to comment Share on other sites More sharing options...
markmaltby Posted May 6, 2009 Author Report Share Posted May 6, 2009 Thanks Jon I have now removed the engine and now awaiting puller from dealers Thanks once again for your help Mark Quote Link to comment Share on other sites More sharing options...
