onechanceeh Posted November 7, 2004 Report Share Posted November 7, 2004 Hi guys My front axle on my 02 sherco is stuck the bolt is half thredded but you can still get a allen key in but it wont turn it has snapped 2 allen keys when i used leverage so any ideas guys? nice one Richie Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 7, 2004 Report Share Posted November 7, 2004 Lots of possibilities, easy stuff penetratig oil make sure allen bolts m6 are removed and pinch wedged open, heat very carefully, get someone who is a good mechanic to have a look, and if all else fails take forks apart hold spindle in vice and unwind fork leg? Lastly drill out, but very lastly....... difficult to pin point whats the best without being there. Bit of horse bolted maintenence, lube the thread next time and take out every few rides. Good luck. Quote Link to comment Share on other sites More sharing options...
onechanceeh Posted November 7, 2004 Author Report Share Posted November 7, 2004 i cant get to the thred all pinch bolts are out Quote Link to comment Share on other sites More sharing options...
marky g Posted November 8, 2004 Report Share Posted November 8, 2004 My 01 250 I used to have was the same, the Axle is made out of super soft Alloy, I snapped one Allen key off and in the end the head of the Axle just started to round off with the second atempt. You can try and impact Air Wrench, probably wreck the head of the axle but it might work. All this was aboout the same time I had quite a few other faults with the bike so I got rid and never did get it out . Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 8, 2004 Report Share Posted November 8, 2004 Seems like that Sherco was not well maintained at all was it M G? Quote Link to comment Share on other sites More sharing options...
duckwizard Posted November 12, 2004 Report Share Posted November 12, 2004 Try boiling water on the alloy part. Sometimes enough to free off. Has worked for me on alloy parts with steel fixings. Quote Link to comment Share on other sites More sharing options...
onechanceeh Posted November 16, 2004 Author Report Share Posted November 16, 2004 i dont think that will work as it is realy stuck especialy as its braking allen keys lol thanks for the ideas guys Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 16, 2004 Report Share Posted November 16, 2004 The spindle is ally and shouldn't be capable of braking 10mm Allen keys something is wrong here. Did you get the forks out? Did you wedge the rh pinch leg open? Quote Link to comment Share on other sites More sharing options...
subira Posted November 17, 2004 Report Share Posted November 17, 2004 Definitely got to be worth dropping the forks out, taking the mudguard stay out and trying to un wind it using the leverage of the forks themselves. Heat up both fork bottoms with water/heat gun/hair drier. As duckwizard says the alloys all expand at different rates, then go for it ! If the spindle breaks then at least you have two managable sized parts to take to you local machine shop. Quote Link to comment Share on other sites More sharing options...
