hollyjake Posted May 6, 2009 Report Share Posted May 6, 2009 is it possible to fit a 1997 xl125 engine into a 1995 cr125 with a few mods ????? thanks Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted May 6, 2009 Report Share Posted May 6, 2009 Do you have the electrics, cdi, carb, airbox etc and access to some steel plate, an angle grinder, a welding machine and a pillar drill? If you do, then it should be possible. If you are thinking of trying to simply bolt an XL engine straight in, then no. Quote Link to comment Share on other sites More sharing options...
hollyjake Posted May 6, 2009 Author Report Share Posted May 6, 2009 thanks yes have all the tools to mod cheers Quote Link to comment Share on other sites More sharing options...
andy m Posted May 6, 2009 Report Share Posted May 6, 2009 If you have the tools and know how a lot can be achieved, look at this. Quote Link to comment Share on other sites More sharing options...
dixie Posted May 7, 2009 Report Share Posted May 7, 2009 If you have the time and the money anything will fit in anything...... When i was a lad a hot mod was xl 185 s in cr 250 or yz 250 chassis if it drives the wrong side turn the swing arm over or put the wheel in the other way round. Good luck Quote Link to comment Share on other sites More sharing options...
rosscoman Posted May 11, 2009 Report Share Posted May 11, 2009 i'v put a few honda cg 125 engines in to the old cr125's the only issue is the drive sproket as the pitch is different i.e chain size, you have to use the xl200 front drive sprocket have fun and get welding! Quote Link to comment Share on other sites More sharing options...
