trialsrfun Posted May 10, 2009 Report Share Posted May 10, 2009 What needs to be done to convert a B40 army type frame to trials spec please. Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 10, 2009 Report Share Posted May 10, 2009 Forks need to brought in for a start. I'm told the frames are double walled, so its always going to be comparativly heavy. Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted May 11, 2009 Report Share Posted May 11, 2009 Hi Guy's. Done one last year, Didn't alter the steering head angle, although it is a bit relaxed, Removed every conceivable bracket and lug, unbelievable weight when all put in a bucket. shortened the rear subframe ,and the most important mod, pulled the seat tubes in, what you will have to watch doing this is that you leave enough room for a straight run with the carb and filter. Yes the frame is heavy but then so is the rest if you use the original wheels hubs forks etc. But you will have a bike that will last a lifetime without a lot of maintenance. PS Thinking of putting a chair on ours, should help me knees, cos i wont have to stand on the pegs a lot. but i pity the passenger. Regard's Charlie. Quote Link to comment Share on other sites More sharing options...
