Fitting Oil Seal
oakworth jon
Hi, I have just replaced the inner clutch casing on an '05 125 due to coolant corrosion.
I also fitted new bearings and oil seal to the impeller shaft.
After flushing and plenty of oil changes I am still getting coolant into the oil and suspect I may not have fitted the oil seal correctly (or is there another cause?)
Are there any tips or special tools required to fit this correctly
Thanks, Jon.
Hi - are you sure it is water contamination? My gearbox oil goes 'white' after starting the engine, but this is due to agitation of the oil and not water contamination..... If it is water, then inspect the water pump shaft for any signs of scoring on the point where the seal runs, and if there is, it is sometimes possible to fit the seal in the housing a little further out (i.e. don't knock it in so far) to allow the sealing face to run on a different part of the shaft.
Good luck :P
