motopat Posted November 18, 2004 Author Report Share Posted November 18, 2004 (edited) The gearbox holds 600cc of oil, make sure you use a good socket on the sump plug (think its 13mm?) as its made of toffee and will round if not carefull. too right it's made of toffee. Stripped it using my 'Halfords professional' socket set, and no bodge tool would get the bugger off - it just got worse and worse (It's 12mm btw) I ended up getting a mate to weild a 10mm spanner to it After 2 spanners and 5 weilds the bugger came off . I am sure all this can be avoided by applying a bit of copper gease to the thread and a coat of oil onto the sealing washer. Grrrrrrr. Thanks to my mate Kevin for the weilding Thanks to Gordon Farley Trials for supplying the replacement FOC And thanks to you guys (esp. Woody who very kindly supplied me with a manual ) Edited November 18, 2004 by motopat Quote Link to comment Share on other sites More sharing options...
davidni Posted July 21, 2006 Report Share Posted July 21, 2006 On my pinky the clutch sticks too but if you put down the back brake and rev i find it frees it up quickly. I think its quite a common problem with the pinkys but then what would i know Quote Link to comment Share on other sites More sharing options...
