Inner Fuel Tank?
jaan
All trials bikes sold in Engalnd during the 1970's had to have a metal tank to be road legal.
Montesa's method of making 348's street legal, was to use this style alloy tank, with a fibre glass outer cover.
Hope this helps
Martin
Edited by MartinM
So this alloy tank was not laminated inside the glass fiber cover? Was the alloy tank mounted to the frame or to the glass fiber cover? What kind of was the tank brackets?
Montesa glass fiber tanks have often problems as all other glass fiber tanks. Would it be worth to use this kind of inner alloy tank?
Jaan
On the 348's the alloy tank sits on foam rubbers pads on the top frame tube. The fibreglass cover had 2 holes for the vent tube and filler tube from the tank. The covers were bolted through the frame at the headstock and had the 2 rubber straps at the back below the seat. It was still possible to lever up the tank/seat unit to get access to the air filter.
Regards
Martin
