Taper Roller Bearings For A Tiger Cub Headstock?
honda pants
i think you will find that the triumph frame bearing housing is a totally non-standard imperial size.
your options are to fit adapotors into the frame to accept a metric bearing. The bearings will be further apart so you will need a longer spindle than the original triumph one and you need to watch the ride height as the top yoke will be higher than before.
alternatively you could weld the fantic headstock to the triumph frame, losing a couple of degress rake at the same time.
