Gearbox Oil Turnt White?
dyk316
There is likely to be two reasons.
First - you stood the bike in water which cooled the engine casing down. When this happens the air in the box contracts sucking water up the breather pipe (this is a REALLY good reason to have the breather up high!). Warm the bike, drain the oil and replace with fresh.
Or Second - your water pump drive shaft and seal are worn. Drain the remaining coolant and white gearbox oil. Replace the part(s). Refill both and go.
