agiow Posted May 17, 2009 Report Share Posted May 17, 2009 Probably a question for Lee Have just finish getting a 200 Fantic back together it ran for the first time today , it run Quote Link to comment Share on other sites More sharing options...
lee harris Posted May 18, 2009 Report Share Posted May 18, 2009 not sue. i think it has a 92 main and 42 ish pilot. Also the circlip is probably 1 clip down from the top. i havnt owned a 200 for several years now...maybe ride better if i did. Bilco, whats the score? Quote Link to comment Share on other sites More sharing options...
whizzy Posted May 18, 2009 Report Share Posted May 18, 2009 The owners manual says Main jet 92, Slow jet 45, needle D33 at the third notch Quote Link to comment Share on other sites More sharing options...
russelld Posted May 18, 2009 Report Share Posted May 18, 2009 I am having the same problem with mine, and had lots of advise from Lee and tried and tested everything, BUT now I think the solution has been found after having a good chat with Bill Pye and also a great guy named Clive Taylor (hope your reading this Lee) the problem I found was the expansion chamber in the front exhaust pipe and not the carb, i had my pipe carefully cut open and found that a large chunk (caked in carbon) of the honeycomb mesh in the inside had broke off and lodged itself to block the exhaust gases travelling through to the silencer, it was fine low range but as soon as you gave it any higher range rev it would just choke up and run as if the choke was on and would want to cut out, then as soon as the revs were dropped and it cleared it would run fine bottom range. I am having my WES silencer re-packed also and getting the front pipe back this week so it has not been tried and tested but I am sure this is the cure to my problem (and hopefully yours) WATCH THIS SPACE AS RESULTS WILL BE POSTED Cheers Quote Link to comment Share on other sites More sharing options...
agiow Posted May 19, 2009 Author Report Share Posted May 19, 2009 Cheer's for the replies I Quote Link to comment Share on other sites More sharing options...
agiow Posted May 20, 2009 Author Report Share Posted May 20, 2009 Last night I fitted all new jet Quote Link to comment Share on other sites More sharing options...
lee harris Posted May 21, 2009 Report Share Posted May 21, 2009 I am having the same problem with mine, ....................... also a great guy named Clive Taylor ....................Cheers yes he is a nice chap ...french....englisch....were all foreiners over here! Quote Link to comment Share on other sites More sharing options...
rontheyank Posted May 23, 2009 Report Share Posted May 23, 2009 This reply might be a bit late for you but I had a new OKO carb fitted by Chris at Classic Trial a couple of weeks ago. Its the first 200 that he has done and he used a 24mm carb. The results are very very good. I will be taking it back soon for Chris to check the main jet as on the day I had an exhaust leak, now that the leak is fixed he wants to make sure that its 100%. It feels okay to me as is, a great improvement. Ron Quote Link to comment Share on other sites More sharing options...
